- cam swap
- Limited power from a backwards wired ignition.
- 351 w rebuild question?
- Need Timeing Help PLEASE!
- 86 302 to 88 302
- 302 Oil Consumption
- Help!! Replacing right side exhaust manifold-1992 351/AC
- Oil Switch or Sensor
- What temp thermostat do you run on your non-computered windsors? Thanks to Crane86 for the idea for
- What weight oil do you use in your Windsor V8?
- bad boy 302
- truck vibrates liek crazy
- timing chain ?
- 302 problems - lack of power - advice needed.
- Differences in 351W?
- 351W / Rough Idle / Can't adjust Timing
- Is headers worth it on a 351w help?
- 302 Don't Run Good!!!!!!
- Torque / Horsepower
- I have a 1992 Ford F-150 XLT 4x4 302
- Warm oil pressure
- Severe Compression Loss
- 351c, 351w, 351HO ??????????????????
- No Fuel in the Fuel Filter...
- 302 blowby
- truck surges when cruising
- need new exhaust
- roush 180cc on a 69 351w?
- NEED HELP!! PLEASE!!!!
- What years, and models offered 351 W EFI??
