need new engine
Old Jun 14, 2001 | 10:30 PM
fightnirish's Avatar
fightnirish
need new engine
can a 302 from a mustang fit in a 84 pickup also with a 302? i need a new engine and im a little short on cash.are wrecking yard engines any good?what type of engines will bolt right up to my truck?
Old Jun 15, 2001 | 03:02 PM
rc351w's Avatar
rc351w
need new engine
A 302 is a 302. There is no difference in the block between the 302's in cars and trucks. To make life easier when changing oil you may want to put a rear sump oil pan on, but if you don't mind a little oil on your cross member then the double sump type will be fine.
RCC
Old Jun 15, 2001 | 06:51 PM
billyb's Avatar
billyb
need new engine
a 302 is a 302, but it may be balanced differently, depending on the year. make sure to get flywheel or flexplate from year of engine to assure proper balance.
Old Jun 15, 2001 | 09:18 PM
Franklin2's Avatar
Franklin2
need new engine
Check out the dipstick location. Some blocks mount the dipstick in the rear/side of the block, some don't. There will be a combo of block-oilpan-dipstick location that will work with any block, but certain parts may hard to find.
Old Jun 19, 2001 | 02:34 PM
crazy_goodolboy's Avatar
crazy_goodolboy
need new engine
Is that stang 302 a 302 or 302HO? They'll both fit, but I was just wondering.
Old Jun 19, 2001 | 05:05 PM
ddime2000's Avatar
ddime2000
need new engine
uncleshepard's69
Jan 8, 2017 06:14 PM
ss27gogeta
58
Jun 21, 2016 06:10 PM
snapy64
New Member Introductions
May 22, 2014 11:32 AM
Colton Yordy
Apr 29, 2012 06:19 PM
marcograms
Jun 18, 2010 06:22 AM
