- Will 88 302 EFI bolt on to a 77 302?
- Difference of F-150,F-350 351
- Idle mixture screws
- Paging Slikness.....question about flywheel on engine swap
- 351W Stroker HP/Torque Results - Theory
- 351 W heads
- 86 302 ignition problem?
- Check out my Combo for Untimate F100 5.0L
- VERY honest answer .....Please
- Bellhousing pattern
- Need help putting 351 heads on 302, need reducer washers for bolts
- Manual Flywheels
- Need deskDyno run for head/cam/intake combo
- 351W 1984 F150. t-18 tranny swap to something w/better perf/mileage
- Fuel Pump Issues with 83 Bronco Manual Pump!
- Operating temp?
- back firing
- Engine Balance??
- 351 to a 302 swap READ LOTS OF INFO
- engine id
- mains or oil pump?
- '86 351w-jet size
- tranny pick
- lift & springs
- Is there a difference between a 4 bbl and 2 bbl intake manifold
- 302 pressureplate /clutch to flywheel alignment ?
- how much compression?
- carbon and sooty carbon
- HORSEPOWER RATING ON A 86 EFI 302????
- carbureator identification
