- 1975 4x4 289 swap
- Cold blooded 302
- 351w Ticking / Knocking thread.
- Common Surging Idle for new guy
- Engine choices
- 347 stroker?
- '87 302 E7TE
- My plan to get better mileage from a 351W
- v8 same as v6 distributor
- early(er) heads on a '96 351w ??
- Distributor woes, 78 bronco
- duel cherry bomb glass packs on 5.0?
- 302 cylinder head question
- The old Windsor Head on 302 discussion...
- 94 F150 302 question.
- Should I fog my 302 for winter?
- Stuck Lifter Help Please
- Edelbrock Performer EFI 5.8 Truck intake
- Max RPM for a 302?
- 1989 F-350 stalls out then won't start?!
- 1998 exploroer 5.0
- Hesitation from stop
- pencil lead brok off in carb throat
- Distributor gear question.
- 1991 302 Oil problem
- Several mods and no power gain
- 3-piece valve spring
- Aluminum Heads or Gears....
- need cam help on efi sd 302
- Starting a 351W build
