- Carb, intake, and head selection
- 86 truck 302 Roller cam ready??
- 302 idle goes up when I apply the brakes; normal?
- Spring seat grinding
- Will I Make It?
- Bit of help with 302 question
- e5te heads
- New Car, New Engine, New Questions
- i'm in flywheel hell
- Aftermarket Intake....
- Timing Issues/Harmonic Balancer out of balance?
- Windsor Intakes
- 5.8 vs. 5.0 intakes
- 351W Fuel Injection Harness
- Coolent vapor coming in through heat vents
- High revving 351W
- head & compression questions...
- Engine won't start, fuel in oil pan
- Heads?
- Timing issues
- Main Studs and Oil Pickup Support?
- 4 BBL Carbs on 302's
- 351 h. o.
- HELP choosing a block-Windsor
- 2.02 valves ?
- valve covers for 351?
- Comp. ratio....
- intake leaking vacuum
- Thin Head Gaskets
- Need help with Codes 21 and 24
