302 Diagnostic Question
Old Jun 21, 2001 | 08:50 AM
poet66's Avatar
poet66
My wife has a 1986 E-150 , fuel injected 302. Will jusdt stop running, especially when the weather is warm (90 degrees). Fuel pump (frame rail) wasn't coming on so I wasted 80.00 replacing it. Sprayed wd-40 on all the underhood connectors. Seemed to fix the problem last year. Drove until yesterday (90 degrees) and it quit again. The fuel pump isn't coming on again. Am about to go check for spark (van is on the side of the road). Is there anything I should check first. What would make the fuel pump not come on?
Old Jun 21, 2001 | 10:13 AM
Franklin2's Avatar
Franklin2
[font size="1" color="#FF0000"]LAST EDITED ON 21-Jun-01 AT 11:14 AM (EST)[/font][p]Fuel pump relay.
Old Jun 21, 2001 | 11:14 AM
poet66's Avatar
poet66
No spark... Would a bad ignition module let it crank for just a minute and then quit again? Someone said the computer won't let the fuel pump run if there isn't spark. How do I tell where the ignition module is located?
Old Jun 21, 2001 | 01:51 PM
lanero's Avatar
lanero
Should be bolted to the dist.
I had the same problem on an '84 and it was the module.
Roger Lane
Test Analyst
Sr. Automated Test Engineer
IBP, Inc.
Old Aug 9, 2001 | 05:54 PM
kilted_drummer's Avatar
kilted_drummer
no spark and no fuel...sounds like the module...did that on my 85 T-Bird and a friend's 84 Mercury (whatever the Mustang clone was then). It ran about 80 bucks and need a shallow walled , I think 8mm socket, to get it off. Good Luck..
Old Oct 5, 2001 | 08:09 PM
Franklin2's Avatar
Franklin2
Old Oct 11, 2001 | 06:11 AM
Bojunk's Avatar
Bojunk
You posted over a month ago but myself and another have the same problem. See "85 F150 302 w/EFI" and "86 F150 302 w/EFI" on the 1980 -1986 Trucks and Vans BB (top of page). We both tried what has been suggested. $$$ Hundreds later we are still trying! Please share your fix with us! Thanks Bojunk
thornton1979
Jun 28, 2013 12:33 PM
302VAN
Jun 27, 2008 07:52 AM
lilwally_90ford
Feb 10, 2005 05:00 PM
rbachmann
1978 - 1996 Big Bronco
Jan 14, 2005 01:05 PM
pizalm
Jun 9, 2004 03:36 PM
