building up a 289
Old Jun 11, 2001 | 01:26 PM
stevieray's Avatar
stevieray
building up a 289
Old Jun 13, 2001 | 12:21 AM
elsmith's Avatar
elsmith
building up a 289
I am going to build up a 289 that is supposed to be out of a 66 mustang. Is there any suggestions on what parts to use? It is just the block and crank. What is the differance between a 289 and 302? Thanks eric
Old Jun 13, 2001 | 12:37 AM
flareside's Avatar
flareside
building up a 289
I UNDERSTAND THAT THEY ARE THE SAME BLOCK, BUT THE 289 HAD A SHORTER STROKE THATS ALL. 302 , 351W HEADS WILL FIT ON THE 289 BLOCK. BYE THE WAY WHAT CODE OF A 289 DO YOU HAVE THERE A-C-D-K(K CODE IS THE BEST IT THE HI-PERFORMENCE ONE)
WELL GOOD LUCK FROM FLARESIDE....
Old Jun 13, 2001 | 02:33 AM
elsmith's Avatar
elsmith
building up a 289
I don't know the code. Where is it at on the block. I am going to drag it out of the back of the garage tomarrow an I will post then. Thanks Eric
Old Jun 13, 2001 | 03:48 PM
elsmith's Avatar
elsmith
building up a 289
The code on the side of the block is C40E-6015C.
I think this is the date code 4D21. Eric
Old Jun 14, 2001 | 10:32 AM
dre's Avatar
dre
building up a 289
Flareside, you have to calm down.
turn thoses CAPS off..
Dre'
1978 F-150, 460ci(750cfm,Edelbrock Performer,Dynomax Ceramic Coated headers,etc.)Auto-C6,3:70.1 - 9" Posi.
Old Jun 15, 2001 | 04:08 PM
elsmith's Avatar
elsmith
building up a 289
Yeah Flareside why are you shouting? Would the oil pan from a 351W fit the 289 block? And what cam do you guys recomend? Is there any way to tell what exactly the engine came out of? There were a couple of people that wanted to buy only the crank but my dad wanted to sell the block and all. Is there anything special about certain cranks? Thanks Eric
