- Which lobe is which?
- 302 build questions
- oil pres
- Performance Upgrade 95f150 351W-GT-40?
- How much to cut heads with no intake alignment problem?
- 351 that sounds like wind
- 351 rebuild
- 351w into '82 F-150 4WD
- Question bout identify engine..
- low oil pressure
- Mileage
- Building my first windsor motor, could use some advice
- 302 Fuel injection problems
- Fordcobraengines.com
- Need Crank pulley and harmonic balancer
- Need Help
- What compression on 302?
- pistons
- Front Seal Help on 302
- pistons & horsepower
- 351W Dead on #8
- more torque
- cam
- 302 how many cfm's
- How to tell 302 vs 351W ?
- 2bbl to 4bbl ?
- 302 miss at idle
- V-Belt swap??
- Idling rough with voltage fluctuations
- 289 Question
