View Full Version : Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
- 351 Windsor one piece rear main seal
- What does a stuck lifter sound like?
- ? about alum heads
- Is this worth 1200$ 96 5.8l 66k
- will this setup work on my 94 f350 351w
- Carb gasket burned up???
- 5.0 hesitates
- Next problem, rough idle, hard start, 351w efi
- 5.0 HO questions
- 1990 351W EFI Won't Advance
- 1.7 roller rockers installed,noise question?
- Where can I find 1 & 3/4" primary headers for a 351w?
- Vacuum advance question
- hp and tq ?
- Temperature reading 85 F150 302CI
- plastic covoer on front intake bolts?
- Engine Swap Help
- 5.8LDistributor Gear...Steel or Cast?
- M6606 on a 351?
- best year gt40 heads
- Converting 302 to roller rockers, what is involved?
- Few Question on Rebuild or buy Reman
- Massive amounts of sludge, 1990 351w, need advice on what to do.
- 302 cough, pop, sputter, idle to off idle
- crud/grime under pass. side valve cover?
- 93 Water Pump Replacement
- 73 302
- Oil in coolant from where???
- Wire seperators 302 carbed
- WCP
