- 4bbl.intake 68'289
- 302 Question
- windsor or cleveland
- weight of these items
- flywheel - resurface?
- is SPOUT connector just a jumper?
- Oil gage line location
- Interesting intake manifold
- oil pump rod won't drop down?
- 302 oil return dimensions? (cylinder heads)
- 302 8# Fuel Fouling
- 302 performance cam question
- gt40p heads
- Newbie engine question?
- 300 Hp 302
- Where to look for casting #'s on a 302 block
- 302 EFI valve covers
- Ingition system upgrade
- Rebuilding 302, suggestions?
- Best cam for 351W
- Water leak
- AC Delco 302 Crate Engine Advice
- Help Me !!... De smog my 86
- install timing chain set? 289
- Installing a harmonic balancer
- getting gas in the oil
- Oil pan/Pump Question
- oil pressure dropping
- Engine Serial Number???
- 68 302 heads on a 78 351W
