mounting flywheel
Old Mar 16, 2002 | 06:27 AM
swirk's Avatar
swirk
mounting flywheel
I am in the middle of my engine swap and have run into a snag. I can't figure out how to mount the flywheel so that the weight is in the correct position. This is a new flywheel and a new motor. Is there a way to figure out how the weight should be mounted? Does the weight sit opposite from the weight of the dampner in the front of the engine?
Old Mar 16, 2002 | 07:14 PM
Franklin2's Avatar
Franklin2
mounting flywheel
The bolt holes will only line up in one spot.
Old Mar 16, 2002 | 07:20 PM
swirk's Avatar
swirk
mounting flywheel
you are right!! I found that out as when I had them both right in front of me. Thanks for the help.
Old Mar 17, 2002 | 09:42 AM
rc351w's Avatar
rc351w
mounting flywheel
huggyb1972
Jan 23, 2014 05:03 PM
1Archerman
Dec 17, 2009 01:08 PM
Mattb6679
Apr 19, 2009 08:10 PM
junkyarddog82
Feb 12, 2008 09:53 PM
steve(ill)
Oct 5, 2005 06:09 PM
