Timing
Old Mar 21, 2002 | 10:55 PM
Shannonm1's Avatar
Shannonm1
Post Timing
What would be a good place to set the timing at on a 351W. I just replaced the motor, kept it stock. It has a 2 bbl carb. I'm looking for the most power and best fuel economy.
Old Mar 22, 2002 | 03:47 PM
fordzrule's Avatar
fordzrule
Timing
ive always set mine at 8 degrees btdc
Old Mar 22, 2002 | 05:44 PM
Franklin2's Avatar
Franklin2
Timing
Bump it up a little at a time till it starts pinging with the fuel you normally run. Then back it off till it quits pinging. This will be the setting that will give the most power and fuel economy.
Old Mar 23, 2002 | 10:16 AM
brett_d's Avatar
brett_d
Timing
