engine overhaule
Old Apr 18, 2004 | 03:53 PM
35l911's Avatar
35l911
Cool engine overhaule
need to know the procedurs and part list for overhauling my 1984 ford f-150 w/4.9 300 I6 I know how to take things apart and put them back to gether but overhauling anything is new to me. this is my first truck and it is ****ing me off with the amount of problems it has. the neglected truck i bought off my mother for a doller because it still had hope the body was desent till an engin problem caused an accedent a 5 doller part that was replaces a week before the accedent failed so i'm getting ready to start replacing any thing that is rusted under that hood
Old Apr 18, 2004 | 07:29 PM
35l911's Avatar
35l911
never mind on this the engine problem is more serious than i can fix the block is cracked at the thermostat housing the bottom bolt will not tighten tryed everything.
Old Apr 18, 2004 | 09:38 PM
Phrogman46's Avatar
Phrogman46
JP Weld will fix it!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 19, 2004 | 05:01 PM
35l911's Avatar
35l911
are they in Oxon hill MD
Old Apr 19, 2004 | 08:04 PM
Phrogman46's Avatar
Phrogman46
JP Weld is a product that you can use to fix the crack. You mix it up and then stick it on, it turns to a metal like materal. Then you just drill and tap it and put the thing back together. You can get it at autozone or a like store.
whiteboy7thst
23
Feb 4, 2016 10:49 PM
IronHorseDriver
1983 - 2012 Ranger & B-Series
Dec 29, 2014 12:25 PM
#1spudman
Jun 19, 2014 12:18 PM
IowanStraight6
The Next Generation
May 4, 2009 08:15 PM
IowanStraight6
May 4, 2009 02:02 PM
