dual quad pics
Old Mar 12, 2005 | 09:34 PM
3008bbl's Avatar
3008bbl
dual quad pics
Hello all, just added a few pics of my lowered, multi-carb'd '78. Enjoy
Old Mar 12, 2005 | 10:51 PM
oldhalftons's Avatar
oldhalftons
DUDE!!
that looks really nice.
Old Mar 12, 2005 | 10:54 PM
GeneStoner's Avatar
GeneStoner
Not that's something you don't see every day! Nice work. Howzit run?
Old Mar 13, 2005 | 12:40 AM
'961506's Avatar
'961506
HOLY!!! I have heard that two carbs can be overkill...Whats your responce?
Old Mar 13, 2005 | 02:07 AM
200000+F150's Avatar
200000+F150
I want that intake. Did you buy it new? If so, what, where and how many monies was it? That setup looks SUWeeeet!
Old Mar 13, 2005 | 11:51 AM
oldhalftons
thats a Clifford intake, still in production.
Old Mar 13, 2005 | 06:30 PM
1982fordf100's Avatar
1982fordf100
I'd like to hear how that 300 runs with two carbs. It looks like nice set up. What else have you done to the engine to help support all that air and fuel? I bet that truck sure moves.
Old Mar 13, 2005 | 10:24 PM
old75F-100's Avatar
old75F-100
well thats a pretty nice set up! what size of carbs are you running and what have you done to the motor to make it run good?
Old Mar 14, 2005 | 11:30 AM
corpsedub's Avatar
corpsedub
one clean 300
Old Mar 14, 2005 | 01:26 PM
Silver Streak's Avatar
Silver Streak
That's sweet.
Those look like 600 carbs. Most of the other carbs use center hung floats. A typical dual quad setup only runs on one carb most of the time, so they don't feel over carbed as bad as you would think.
Old Mar 14, 2005 | 09:31 PM
3008bbl's Avatar
3008bbl
Thanks for the compliments guys. I've been running this set up for about 7 years now. Yes, the intake and valve cover are Clifford pieces, but thats it. The carbs are 390's set up 1 to 1, meaning that I run on both primaries at the same time. The reason I chose this intake was for two reasons, fuel distribution, and the cool factor. The engine has been bored .030", block decked and head shaved. Compression is 10:1. The camshaft is a custom Comp. Cams grind with a 280 duration and a .512 lift. The head has been ported and treated to 1.94 and 1.6 valves topped with Crane roller rockers. The ignition is Holley Annihilator, the headers are form Hedman exiting through 2 1/2 " exhaust. A Holley "blue" fuel pump feeds the beast. The tranny is a top loader 4 spd. from a '65 Mustang. The rear end is a Nodular 9" with 3.89 gears and a Detroit Locker. Cruise at 60 is about 3,000 rpms. The truck has been lowered and a set of custom fabricated ladder bars control the wheel hop. Sorry, no pics of the ladder bars yet. When I get some I'll post them. I don't believe the engine is over carb'd, in fact, according to the spark plugs, the mixture is just about right. The truck is fun to drive and could be driven daily if needed. I get about 11 mpg on a good day, but if I play then its closer to 7-8.
Old Mar 15, 2005 | 07:56 AM
Red2003XLT's Avatar
Red2003XLT
How low did you drop your pickup?
Old Mar 15, 2005 | 06:18 PM
3008bbl's Avatar
3008bbl
3" in the front with DJM beams and about 5" in the rear with their shackles and hangers. I also removed a leaf.
Old Mar 16, 2005 | 09:56 AM
Red2003XLT's Avatar
Red2003XLT
Your stance is right on, very nice.
Old Mar 17, 2005 | 01:08 PM
I6power's Avatar
I6power
ive seen the parts but ive never seen them on a 300. in short, your my hero
