Oil Pump Replacement
Old Mar 12, 2005 | 05:35 PM
Weasel's_Truck's Avatar
Weasel's_Truck
Is the Oil Pump an easy replacement on a straight six?? I guess what i am asking is can i just pull the pan and replace it??
Old Mar 12, 2005 | 07:07 PM
paulfix's Avatar
paulfix
Yep, getting the oil pan off and on is the hardest part.
Old Mar 12, 2005 | 07:25 PM
Gary B's Avatar
Gary B
the oil pan on a 300 six cylinder will not reasonably come off without pulling the engine, sorry
Old Mar 12, 2005 | 07:27 PM
Weasel's_Truck
You say reasonalably, are you implying that that some models it is possable????
Old Mar 12, 2005 | 07:37 PM
Gary B's Avatar
Gary B
the engine has to be raised so high and so much disconnected, rad hoses,ps lines, exhaust, upper intake,and it still may not come out. if you are not set up to pull the engine forget it.
Old Mar 12, 2005 | 11:17 PM
RNE's Avatar
RNE
On older )pre-injection( F150/250/350 models it isn't that hard, done it many times, disconnect hoses ETC, jack up engine, pull pan.
No sweat, well, for me anyway.
Old Mar 13, 2005 | 01:56 PM
Weasel's_Truck
Mine is in a 88 F-150 4WD, boy it sure looks like I can get the pan off without any extra work. You guy are sure the engine needs to be jacked up.
Old Mar 13, 2005 | 02:17 PM
Ford_rulez19's Avatar
Ford_rulez19
I had to jack the engine pretty high to get off the pan yes it's alot of trouble mines a 94 dont know bout older ones
Old Mar 13, 2005 | 03:50 PM
Weasel's_Truck
Ok well i am convinced. i am not going to rush out and do the oil pump
Old Mar 13, 2005 | 04:05 PM
gravedigger's Avatar
gravedigger
just replaced oil pan on 95 without removing engine.
Had to loosen wiper moter for extra inch it was snug
but doable
Old Mar 13, 2005 | 04:24 PM
noFordguy's Avatar
noFordguy
to change the oil pump is easy. losen the fan shroud(8mm), take inspection cover off trans(3/8) undo engine mount bolts(18mm), jack engine up buy harmonic balancer(till the end of engine mount studs are .5 inch above engine mount plates, stick 1x3 under mounts to support engine, undo oil pan bolts(1/2), let pan drop to cross member, undo oil pump(5/8), let it drop in pan, slide pan out,reverse to install. the fel pro gasket kit comes with oil pan holders to hold the gasket to block. i just make sure old gasket is scaped off surface and stick new gasket in place, no sealer,when pan is installed just push up and the pan is held in place. see simple iv done them in vans, p-ups,and just about every thing else the inline is in. iv got it down to 35min w/air tools of course. my first one took 2.5 hours with hand tools in my drivway.
Old Jul 3, 2005 | 08:47 PM
spurredon's Avatar
spurredon
When you get my age, it takes you 35 mins. just to change the oil!!
