- 300ci rebuild...suggestions
- A question about heads and Fuel delivery
- Engine+Trans
- 4.9 Mass air Years?
- Carb vs. FI
- 300 carb problems
- Offenhauser C-series or Dual plane?
- 1995 4.9 timing degrees????????????????
- MSD Ignition
- Water Capacity
- Loose Manifold Heat Riser - NOISY
- YF1A question
- Differences between 300 flexplate and 302 flexplate
- Straight piping a I6
- offenhauser inake + headman headers
- 2-barrel questions
- How about a jake brake for 300 I-6?
- Towing boat with 8ft cab over camper?
- Cracked block?
- Aluminum?
- split manifold
- unstable idle and stalling upon acceleration
- Bottom End
- Too Cold
- Compression Test & More
- Does anybody offer a roller cam?
- Whining noise
- Iat ?
- Bad Gas Mileage
- will a bell housing off of a 300 I6 bolt up to a 351W
