Depending on the year, yes they could share the same tooth count.
They are the same diamter.
But they don't interchange.
Reason being, the 300's flexplate/flywheel has a neutral balance, where the 302 depending on the year, was either 28 or 50 oz imbalance.
Perfect thats all i needed to know. I'm looking at buying a adapter kit designed to bolt a 700r4 to a 302 and wanted to make sure that the 300 flexplate was the same because then the kit should work for me.
You realize I was saying they are different, right?
I do realize what your saying. I know that they are not interchangeable but if they are the same diameter that means that the flexplate on my 300 will work with the kit. I was just worried that the flexplate on my motor was a different diameter than the 302 which would mean the starter wouldn't line up if i used this kit.
Sorry about not posting back sooner, been away working. The reason i'm using a 700r4 instead of a AOD is i'm getting a 700r4 for free from a buddy and tracking down a AOD in this area had been hard. Most of the places around here don't have the AOD or have stock rebuilt ones. I don't want to pay around $1000.00 for a stock tranny. This truck i'm building is going to be driven pretty hard and i want an overdrive tranny that can be built to take the abuse.
