Whining noise
Old Dec 9, 2005 | 06:03 AM
beatupford's Avatar
beatupford
Whining noise
I get this noise when i drive my truck now, it started last summer. I recently changed the throttle body gasket that was sucked in, so it runs better but still pings a little now and then sometimes not at all. But now when i accelerate, but not flooring it it has this high pitched whine to it, kind of like a constant high pitched whistling or ringing noise, hard to describe. The pcv valve is ok. When you let off the gas, the whine rattles and starts to fade away into a light rattle, the whine doesnt sound bad, the truck has always had that whining noise to it, but its louder and sounds a little different. I'm wondering if that whine to rattle noise is just associated with timing or the knock sensor. Or is something way more serious? Thanks eh.
Old Dec 10, 2005 | 08:39 AM
Motorhead351's Avatar
Motorhead351
does it make this sound at idle or when you rev it in neutral?
Old Dec 10, 2005 | 12:10 PM
beatupford's Avatar
beatupford
No at idle its fine, no whining noise, valve noise sounds a bit like a sewing machine but thats it, slight miss, and the rpm bounces from high to low slightly. It runs fairly smooth in neutral no shakes or knocks. In drive, almost sounds like, you know when you put your finger on a crystal glass, just a faint sound like that especially when your picking up speed. Its really high pitched. Sound of motor normal "buzz" with that high pitched whine in the background. It really starts to go when you take it out of overdrive and drive steady like that for a while. At really light throttle, the whine is more of a very faint rattle, more throttle-more whine, From a little to WOT, you dont hear it at all. I wonder if the rattle is just pinging and that whine had something to do with it. Sometimes you can hear just a faint little rattle before it finally dissapears. Just cant figure it out. Weird eh?
Old Dec 11, 2005 | 09:08 AM
Motorhead351
You got me, your sure its coming from the engine bay and not elsewhere?
Old Dec 11, 2005 | 01:25 PM
beatupford's Avatar
beatupford
I hope its elsewhere. It starts up as a rattle, but whetever it is the rattle turns into a whine as it picks up rpm. no what i mean? So im hoping its the airpump, altenator or something, i can live with that. Or im thinking the rattle is actually park throttle ping from a leaned out mixture caused by a vaccum leak. And as vaccum increases you hear it more, but at WOT you dont hear it, there is no vacuum right? It is more pronounced under load, even when taking off after 3 minutes of starting up. So i could disregard the ping because the temp hasnt even reached N on NORMAL. I dont know either, ill have to check it out when it warms up a little.
Old Dec 11, 2005 | 04:52 PM
Motorhead351
Any chance you could try a dowel rod to the ear...to pinpoint the rattle at idle?
Good luck
Old Dec 12, 2005 | 06:22 PM
beatupford's Avatar
beatupford
Wish i had a soundclip...
Reggie31
2004 - 2008 F150
Jun 17, 2021 08:32 AM
PAracephan
Feb 13, 2021 07:37 PM
RobbyMartin
1997 - 2003 F150
Sep 5, 2010 09:46 AM
Labgal
Dec 5, 2008 03:24 PM
blueangel
Jul 25, 2003 12:20 PM
