- power steering pumps
- What a Find!
- heads
- grind on valves and seets
- 390 ???
- Exhaust Cutout?
- Pulling Engine
- distributor replacement help
- edelbrock performer rpm packages
- maximum MPG tweaks/modifications on the 390
- compression on 390
- Oil Pan
- Leaky 4x4 pan fix
- AOD to FE
- 390 ram air
- Help w/ ignition upgrade
- blow by causing excessive oil leaks?
- Distributor Springs Again
- 360 running rich-no power-poor milage
- carburator exchange
- outlet on the back of 4bbl intake
- Vacum routing
- carb causing a miss?
- 360 heads
- Best plug wires?
- 390 Camshaft Thrust Plate
- Clutch info 351M/400 to 352???
- Questions 390 vs 428
- The 390 vs 428
- correct thermostat temp for a 390
