- Will FE start being off a tooth on the distributor
- Low Buck Stroker
- Head mis-match
- RV cam???
- Questoin about block stamp and VIN on my 69 F100
- How's this sound-390 stroker
- These numbers aren't good...Head problems..Long
- Boring a 390
- fe re-build kits
- what do i have
- 428 Crank balancing
- Ignition/Distributor question
- Good thing to know.
- Carburetor-heat passage in intake manifold...
- Scat 66490 428 Ford H beam rods
- 5speed FE
- nitrous FE
- 67 f100 new tranny
- 390 pre-lube
- Candy Store
- Intake/Exhaust Valves
- Junk Block?
- Which Distributor to Use?
- Fe trans. question?
- 427 i.d.
- Points system problem? Newbie
- bellhousing info
- Simple engine temp. question
- Advice on camshaft
- Head options
