- carb issues
- TB 390 engine code Z
- FE Block Clutch Fork Pivot.
- 360 block-67-427
- Cutting 428 heads
- what kind of cam do i need??
- 352tranny
- Piston to valve clearance?
- edelbrock adjustment screws
- new to forum, need guess on tq and hp #'s
- 390 timing question for gurus
- Aluminum 427 Update
- FE motors
- 390 Exhaust manifold bolts....
- Ed heads, inadequate oil return?
- 428 head casting numbers
- Hedman Header ??
- hydraulic roller cam
- Holley 2300, which one for a 390?
- Novice Question
- can this be done?
- ROCKERS not staying on
- FE V8's
- great engine find
- Autolite 2100 stop screw is stuck
- Carb Spacer w/Heater Hose
- horsepower
- 390 vs. 460
- Id # for heads
- Firing order
