- 390 parts
- How to identify a 360 between a 390
- Chiltons or Haynes manual for 352
- Can Performer RPM be too "hot" ?
- Help!!!!!
- 352 running rich
- Compression ratio help
- Cam Bearing Retainer Plate Question?
- Looking for a machine shop in central AR
- 406 History?
- 73 f 250
- stock 360 to 390 or a 428?
- Baffled Oil Pans
- Coil hookup...again
- Blowers For Fe
- The Best Gasket Set
- 428 or 390 build up
- I have the #'s so what do I need?
- Just ordered the Performer RPM intake.
- Gear Drive
- need some advice on trickig my 390....
- clapping sound on a valve...
- Babying the 352
- Need advice, ticking not good!
- FE motor mounts
- Heli-coil and replace bolts with studs
- compression test; now what do I do
- Well the 428 block comes in from KC, on monday!
- Changing lifters without removing intake manifold?
- Upper engine "rap", completely stumped
