- need FE hyd lifter like this...pic
- crane 904?
- need parts
- RPM=gear ratioXmphX336Div.by tire dia.
- holley 4160/600vac-sec brain picker
- Locked up 352 mystery solved
- How do I remove the cap screw?
- 428 Block Codes
- Water Pump to Intake 1.5" hose... something better..
- Hi Lift rocker arms
- I need motor advice
- Erson roller rockers or Crane roller rockers???
- Trying to find correct hyd lifter for 74 390 4bbl and length of stock pushrods
- 4v intake found!
- Oil pump drive shaft
- Your post rebuild break in technique?
- distributor
- need help fellas
- flywheel for 352
- FE Head gasket sealing for thin steel shim gaskets
- Intake pre-heater.
- Bits of plastic found in oil pan?
- Russ, here's the cam specs...
- Timing chain
- just for fun, new Video!
- Quickest way to a positive i.d.?
- FE's RULE!!!
- Ahhhhhhhhhhhrrrrrrrrrrrrrgggg!!!!!
- Hey G, Regarding the 3 -428's
- need header/oil dipstick solution!
