- oil filter leak
- New idea, putting a FE 390 in a bronc.
- Tall FE valve covers??
- front cam bearing grooves -- which way???
- New Cam!
- Help 352 , 390 need help to identify
- rebuilding head's
- 390 or go 428 ?
- Seeking opinions on fram oil filter causing low oil pressure?
- Sticky lifter
- 390 Alternator Pic... please!
- upgrade advice
- 390 after mkt intake manifold
- Holley carb
- 360 Manifold Trouble
- New Oil Pan
- what size exhaust to save my low end power?
- hoisting a 360
- Which 8mm wire set for 360 with flat cap?
- Carb Spacer 390
- Carb recommends
- 4 barrel intake on 360/390?
- Concerning Gunk 5-Minute Motor Flush
- Engine casting #'s
- Horsepower/Torque Questions
- Anyone have problems with low oil pressure?
- from points to Pertronix
- thunder AVS vs. street avenger
- "Pink Spring" ?
- New motor break-in advice
