What a Find!
Old Dec 25, 2003 | 08:46 AM
1978Bronco's Avatar
1978Bronco
Talking What a Find!
Well, it turns out it is indeed a fresh 390 FE,thanks for the information.The block code comes back to a 1968 ford T-bird,4V 390 GT.The head code comes back as 1970-71 429 SCJ police.And I was wondering why im doin 65 when i finally hit fourth gear in this 6400 lb monster...
Old Dec 25, 2003 | 09:00 AM
DuckRyder's Avatar
DuckRyder
429 heads don't fit FE's. - It is a LIMA motor.
428 maybe?
Old Dec 25, 2003 | 09:53 AM
fordman428's Avatar
fordman428
what is the block code and duckryders right 429 heads dont fit an FE.
Old Dec 25, 2003 | 10:48 AM
BB's Avatar
BB
Quick question, how many bolts holding down the valve covers? That'll tell what engine family right away.
Old Dec 25, 2003 | 11:10 AM
1978Bronco's Avatar
1978Bronco
cast #'s for this engine
engine-C8SE 9425B
heads-C9VE-A
Old Dec 25, 2003 | 11:48 AM
1978Bronco's Avatar
1978Bronco
apparently,the site i found with cast numbers is wrong(i think),my friends father tells me the motor is a 429...jeeeez,and i thought i was done researching
Old Dec 25, 2003 | 11:58 AM
1978Bronco's Avatar
1978Bronco
valve cover bolts
Originally posted by BB
Quick question, how many bolts holding down the valve covers? That'lseems kinda odd to me,but there are 7 l tell what engine family right away.
There are only 7 valve cover bolts
Old Dec 25, 2003 | 12:46 PM
BB's Avatar
BB
It's a 429 Thunder Jet, the 9425 # is for the intake manifold. Check out this site and the links for more info on casting #'s. Merry Christmas!
http://429mustangcougarinfo.50megs.com/components_3.htm
Old Dec 25, 2003 | 06:05 PM
1978Bronco's Avatar
1978Bronco
429 thunderjet
BB,Thank you very much for the info,maybe now the parts store can get me that damn oilpan gasket i need...if you could provide any further information on this block,that would be greatly appreciated.the motor was rebuilt last year and sat in this bronco because those idiots didnt know how tp make things work properly...i got the truck for $300.00,put a carb on it and it started on the first bump of the key after sitting for so long...just a few weeks ago,i put the truck up for sale for 1500.00.needless to say,it is no longer for sale...again thanks
Old Dec 25, 2003 | 09:50 PM
1978Bronco's Avatar
1978Bronco
Now if i can only figure out exactly which ford the motor came out of....any ideas?
Old Dec 25, 2003 | 10:20 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check out the 429/460 engine forum.
Old Dec 26, 2003 | 03:26 PM
1978Bronco's Avatar
1978Bronco
seems the 429/460 forum is not very informative
still trying to figure out exactly which 429 this is
4 C8SE 9425 B
BO11
Old Dec 26, 2003 | 04:47 PM
DuckRyder's Avatar
DuckRyder
as bb stated the 9425 # is the intake manifold.
I suggest that if the 429-460 forum can't help try
www.corral.net
www.clubcobra.com
www.stangnet.com
I'll try to did out a book and look some numbers up, but if they are anything like FE's the casting numbers are nearly meaningless....................................... .........
Old Dec 26, 2003 | 05:12 PM
1978Bronco's Avatar
1978Bronco
thanks,im still digging through pages and pages on this endless circle of links and pages
Old Dec 26, 2003 | 06:45 PM
DuckRyder's Avatar
DuckRyder
C9VE-A are 1968-1972 429-460 heads. Non high performance. 2.09x1.65 valves and 2.18x1.87I / 1.99x1.30E port sizes.
The book says you need to pull the pan to see if it is a 2 bolt or 4 bolt block. D0OE-B is the only High Performance block listed, it is a 70-71 429CJ, SCJ, PI block.
If the thing has an aluminum tag with numbers bolted to the intake, that would help.
The intake number isn't in the book, but it is not either of the two high performance ones listed.
Does it have a Rochester or a Holley/Autolite pattern?
All of this is according to "Ford High Performance Parts Interchange" by George Reid.
HTH
