- 2 427's on Ebay, buyer be aware
- The Ugly Drag Truck Is DEAD
- Have to pull engine at 1000 miles
- 390 Rebuild
- Any of you guys running a Ford 4v manifold with no spacer on any FE?
- Single pattern cams
- block I.D. #?
- 390 Ring end gap
- Lifter Oil Baffel
- 390 oiling syste
- 391 Heads
- Mercury Marauder Super 390
- Spiral Lock Retainers
- 352 to ?
- Friend gave me a fresh 390, talk about luck.
- Batmobile used a 390!
- 427 swap?
- 4 Barrel Truck Intake
- Building an fe rat motor w/330 crank?
- 390 Crank I.D.
- Can I and how do you turn a 360 into a 390!!!!!!!
- 390 build-up
- Starting my 390
- first time at track...13.85@105mph
- Dyno2000 -- 360 vs. 390
- Oil changing questions
- Will this work?
- Piston stampings
- engine in f600
- Question on GT heads vs stock
