- crank ID
- FE oiling earthworms&elsmith
- Just a simple ignition upgrade question...?
- 81F150 390/360????again
- carb kickdown linkage
- 302 to 360/390????
- Head Gaskets
- Pistons for a 428
- Cam bearings is it worth it
- Good gas mileage on a 390 unattainable?
- FE Big Blocks
- Engine identification
- 361 to replace a 390 in a '75 F350, problems?
- 428CJ in '85 F-250 4x4
- What I found in oil pan
- 390 Heads
- cooling problems
- Exhaust pop
- Replacing rod bearings
- rattle in 352
- 360-460 conversion
- 352ci Heads.
- 1966 F-100 with 352ci
- Noisy Fuel Pump - any ideas?
- Hats off to Barry
- Police motor?
- Let's talk 360/390 cams for towing/hauling...
- 390 Hp from factory
- 390 or 360???
- Best way to achieve 10:1 compression in my 390?
