- 390 heads to 427 low risers
- FE's dimensions?
- 428 or 428cj which do I have?
- Pvc ??
- Will a Cobra "T" sump pan fit a 72 F100 2 wheel drive
- dual carb intake
- Timing question
- Causes for low oil pressure reading on gauge?
- a few q's
- "U" Shaped Pipe On Hooker 6903
- build my new engine
- Ford MS Cam
- Can we FT folks come to the party?
- Shorty Headers
- white smoke from exhaust and backfire at idle
- How easy is it to come across a 352
- 390 Crank question
- what pertronix system
- Fe Tranny's
- 360 Vacuum question
- Porting Question
- FE 360 rear main seal question
- 69 F100 w/361 possible engine swap
- effects of egr removal
- 351M to 390 swap
- identifying a 428
- Id'ing a possible FE Bigblock
- 428 Stroker On the Way
- 390 Starter/Header clearance
- Is it safe to advance timing this far??
