- Do you need to hone cylinder with different grit for moly rings?
- ?pulling distick tube in th junkyard
- Recurring Rear Main Leak
- Head leaking oil on my brand new 390!
- Water pump info
- Is 390 to 428 a good idea?
- Anyone done the Valve Leakdown Test in Steve Christ Book?
- blocking off exhaust cross over
- FE?
- My spring project
- 390 rocker shaft springs
- Knocks under Load
- Where can I find the oil mods precedure?
- 390 has hole in piston, should I buy new or used one?
- Advice for 390 buildup
- Probably the last time on FTE for me for the next couple months.
- blowing off the oil filter?
- more info on Ident Engine
- 390 rebuild
- Target/crate motor identification numbers? Please Help
- 302 guys didn't have a clue
- Simple 352 rebuild
- Thunder Rolls... But
- Rear Main
- where is the casting #???
- how does this sound?
- Which Pertronix for 72 360, Calif Truck?
- 390 hp??
- Performer 390 intake, bolt torque specs????
- 302 -351 swap, Harmonic balancer and Flywheel READ LOTS OF INFO
