- New engine
- Anyone running Milodon Gear Drives?
- 428cj lost power why?
- Motocraft for my FE
- Rocker shaft recommendations?
- Thermactor exhaust port bump removal
- noisy fuel pump
- 427 Interceptor value
- Cam recommendation for 352?
- 360/390 casting #'s
- 76 390
- 430 stroker FE
- 390 racing at idle.
- 428CJ installed and running....
- 351c to 390
- Compression test readings question
- 390 stroker or 460
- what might happen??
- FE cylinder head oil restriction
- 390 Exhaust Manifolds
- Stock C.R. 390
- 390 heads/bolts/sealer
- Compression ratio
- carb upgrade etc.
- Balancing 390 connecting rods
- FE intake manifolds, new vs used
- Aluminum Intake
- How far retarded
- stock or edel heads
- New to the FE
