- Curiosity
- 390 damper
- Rocker arm shaft drain holes
- The time has come...
- RV Cam
- Best cam for a 390....and raideator
- 428 CJ heads or other iron???
- Rebuild kits
- Power steering pulley size
- 390 Just Dies!!!
- oil dipstick and tube
- time to get my build going help
- Rear Seal
- Periodically, White Smoke RH Side Exh Only
- Replacement Starter... what?
- PS Pump Pulley
- Pg 57, Steve Christ
- 360 Rods in 390. Vibration concern??????
- Push Rods
- New Kid
- Piston Crud
- Paint
- Coolant Leak - Latest Update
- New aluminum heads for FEs...Pics
- C7AE-H heads - why different than C6/C8?
- Single/Dual plane
- High Output 360?
- Does I.M have to be removed to take heads off?
- check this out!!!!
- block casting #
