The 390 vs 428
Old Dec 18, 2003 | 11:21 PM
jambroson's Avatar
jambroson
Question for the Gurus 390 vs 428
I have two vehicles. One is a restored 65 T-Bird that I put a rebuilt balanced 428 in and stock intake/exhaust manifolds with an Edelbrock 650. The T-Bird originally had a 390. The second vehicle I have is a 1968 Ford F250 that needs restoration, but I have become quite enamored with. It has a stock 390. I just ran a compression test and all cylinders came out between 120 and 130.
Here is my predicament. I am going to sell my T-Bird and fix up my truck, but I am considering swapping the motors and putting the 428 in the truck and selling the T-Bird with the 390.
Is it worth the effort to hold onto the 428?
Will the 428 perform much better than a 390 provided I upgrade the Intake Manifold and Headers?
What is the value of a 428 vs a 390.
Your help is appreciated.
Josh
Old Dec 19, 2003 | 12:02 AM
baddad457's Avatar
baddad457
The 428 is worth more than the 390. as far as performance, there's not a whole lot of difference between the two. You're talking about a 30 hp difference. If you think it's worth the trouble to swap engines between two vehicles then go for it.
Old Dec 19, 2003 | 08:49 AM
jambroson's Avatar
jambroson
I need some help from the Gurus
Josh
Old Dec 19, 2003 | 08:56 AM
William's Avatar
William
I'd move the 428. You know what is in it, and the T-Bird would be closer to original with a 390.
Old Dec 19, 2003 | 09:14 AM
Scouder's Avatar
Scouder
Keep the 428. It has more value at resale time, and has better potential as a truck motor due to the longer stroke, which translates to better low end torque. Besides, when you tell someone your truck has a 390 (yawn) it's common, when you tell them you have a 428 their ears perk up.
-Scouder
Old Dec 19, 2003 | 09:27 AM
Freightrain's Avatar
Freightrain
You can make more power EASIER with the 428, but the 390 can serve you well also. It depends on what you plan on using the truck for.
If the 428 is just a plain jane'r(ie: not a CJ, SCJ or PI motor), then basically it is worth just about the same. As long as both are in same condition.
I would probably keep the 428, due to the fact they are getting harder to come by. The 390 was used ALOT more, so they are a bit more easier to find(used in trucks up thru the mid 70s). The 428 was done by 69 or so.
Just my thoughts
Larry
Old Dec 19, 2003 | 10:32 AM
DuckRyder's Avatar
DuckRyder
I agree,
Worth the trouble to swap.
Old Dec 19, 2003 | 12:39 PM
Putt's Avatar
Putt
If you have the chance to keep the 428 DO IT!!! They definitely have more pulling power(torque) than the 390.
Old Dec 19, 2003 | 01:12 PM
jambroson's Avatar
jambroson
Thanks for teh reply
It is a "Plain Jain 428". You think it will be worth the labor of swapping the motors?
As far as the truck is concerned, it is pretty much going to be for going to Home Depot. I want to restore it and I might do some occasional towing of car trailers, but nothing major.
I live in Phoenix and the 428 seems to run a little warmer than the 390 in the summer. Both vehicles have new radiators. Do you think new intake/exhaust manifolds & ignition will help this?
Josh
Old Dec 19, 2003 | 02:50 PM
banjopicker66's Avatar
banjopicker66
You might want to check out that "390." 352s and 360s have a mysterious predilection of transmogrifying into 390s on sale day. It is highly probable that your engine is not a 390 but a 360. If your VIN indicates a 390, and the engine looks original, then you should be good to go.
Otherwise, I think you would do better to keep the 428 in the T-bird, just for originality's sake. If the T-bird VIN calls for a 428, I believe you can get more out of the T-bird with the 428 for it's originality than you can get out of the 428 separately.
For your truck, the 390 will do quite well, it will deliver all the power you will need, especially since it is in such good condition.
Just my thoughts.
Old Dec 22, 2003 | 11:42 PM
jambroson's Avatar
jambroson
Thanks for all your help. The 428 in the T Bird is not stock. It actually calls for a 390.
I think I am going to swap the motors. I will keep everyone posted.
JOsh
gemutlich
27
Jun 6, 2017 04:54 PM
sixtyfive_ford
Nov 2, 2016 08:48 AM
jdteichmer
Sep 11, 2016 10:39 PM
Purebeef
Jul 7, 2014 05:09 PM
77fordguy
Feb 15, 2005 08:36 AM
