- Performance Cap and Rotor?
- valve retainer sleaves
- alternator bracket help
- 390 oil preasure
- misfiring at 3500+ whats the cause?
- Help with a 390
- 360 converted to 390
- carb for 390
- Ignition problems
- Weird FE combo at the track yesterday....
- Weird bogging problem,,,,,
- Starter woes finally gone..
- Rebuild Options
- Headers on my 390
- 390-427 whats the difference???
- vaccum
- Is there a rear sump oil pan for FE's and 67-72 trucks???
- Holley 4412 or 2300
- Clutch Pilot Berring
- Milodon 7qt pan with main studs.
- 360 spark plug gap
- 360 timing problems
- Adjusting float bowl on mid sixtys 4v?
- Vacuum problem?
- 390c
- Autolite 2100 Throttle Sticks
- will I gain much from porting a set of c8ae-h heads
- Update on "Had to pull engine at 1000 miles"
- EGR intake plugged
- 390, sticky lifter?
