correct thermostat temp for a 390
Just a thoght here about what temp is optimum for 390 performance . The motor has been done up a bit I dont know specs it has a 650 cfm Edelbrock carb 4bbl and headers I finally rigged the gas pedal to fully open but the carb almost hesitates and coughs on real hard acceleration also what timing should this motor be set to 15 - 18deg ? Thanks all it just needs a little refinement sure goes once the revs are up in 3rd .
ktownford
68 4x4 390 ,435np ,
205np 4:10
ktownford
68 4x4 390 ,435np ,
205np 4:10
My experience has been the 180 degree thermo is the best. However, I do live in the SouthWest and our winters are very mild at best. Plus, I do have an electric fan setup...which allows me to select when the fans come on for cooling needs.
Timing the 390 goes something like this. Start at 8 degrees BTDC (compression stroke) and work your way up (10, 12, 14, etc.) until you hear the engine ping. At that point, go back down to the previous setting. Takes a little longer, but usually works very well.
Carb issues are difficult. Could be the timing is off enough causing the hesitation. After you have the timing all squared away, then make the fuel/air mix on the carb on the rich side. Again working back to the lean until the 390 responds. This is all said not knowing if you need a tune-up (dist. cap, rotor, wires, spark plugs, fuel filter, etc.)
++PLUS++ When you have the #1 spark plug out centering the 390 for for TDC...check the plug. What does it look like: light, dark, oil covered, etc. Tips you off how the carb is running...lean/rich.
I run a 160
I had a 190 but I had to replace it (due to water leak)
With a 160 it seems to run good, but I haven't gotten much "road use" out of it yet
But idling it takes forever to warm up still, and I don't have to kick the fan on until after I shut it off. Thats if I let it run for 30 minutes or so
Nick-1973-ford
15
12-10-2016 05:03 PM
Dot Heton
04-15-2016 11:27 PM
collinrandle
08-31-2015 11:14 PM
knash0727
01-25-2010 02:21 PM
BigBad352
03-21-2007 01:04 AM
