- 390 into 79 F150 4x4
- What is min valve stem seal clearance??
- Thermostat housing question
- Wrist pin oiling
- New distributor fit.
- Very strange noise during acceleration
- where is the oil going?
- Cam ???'s
- Looking for main stud girdle
- Urgent need 352 iol pump shaft help
- 511 project update...
- 302 vs 390 weight differences
- rebuilding the 390
- 360 Fire and Fuel
- Total advance on a modified FE
- Male fitting where PCV goes in valve cover?
- 410 (428 crank) to an NP 435 - what do I need?
- whats this worth
- Possible carb issue?
- C7AE-B Heads
- fe in a 85 f150
- Wierd FE problem
- Starting FE 390 after 1 year of storage
- best exhaust setup for a 390?
- Would a 460 intake fit a 360-390 ??
- Vacuum advance can with PV switch
- Straighten me out on engine noise!
- Piston pin bushing question
- HELP! found a threaded allen head in oil pan
- whats the advantages of
