- What tach to buy for 390cid
- Wrist Pin Keepers
- 390 timing how many degrease out should it be
- Can a 352 be bored to 390 without sonic checking?
- possible reasons for a hard-starting 428?
- Are the oil mods necessary ???
- burn out tip
- 1970 360
- Rocker shaft oil holes up or down?
- Machine Shops
- Other Rebuild Part to Consider
- AOD for an FE???
- Preferred Ignition Systems?
- (more) 4v Holley Carb Questions!
- 390 A/C Brackets
- Building a 390, would like some advice.
- Smoking 360
- intakes
- casting numbers on intake
- New To Board
- New manifold
- Cams
- 390 rebuild
- Machine Shops
- 390 Rebuild Kits
- Comp Ratio ?
- 352 Horsepower
- Carb Idle Problem
- 410 mercury clone
- Piston ID
