- cam bearings
- Can somebody explain why the FE has such a bad reputation for mileage?
- Looking for some proven torque combos for the 360
- Clutch Fork Lever
- 360 water pump problem
- Offy 360 deg any good for torque?
- distributor dif
- Ford 428 Cobra Jet Engine Block & Cylinder Heads
- PQ Series Shaft Mount Rocker Arm System - 3339022
- Question for Ford parts guys
- It won't be long now...
- 390 Build Update
- 390 vs 302 gas mileage
- Ford 360 Vacuum Diagram
- Can a kickdown lever be added to a Holley w/o one?
- "352" casting
- Frankenstein F-350
- Blown Head Gaskets
- Excess oil smoke
- new engine lifter noise
- Camshaft question
- Ford 390 cu. in. FE-Series Engine
- Looking for a dip stick and tube
- "R" Code heads w/ an "S" code manifold
- Oil pump drive shaft
- Need help tuning a Holley 4160
- 427 design bought from GM?
- Harmonic Balancer?
- 360 rebuild ?
- distributor and edelbrock intake problem
