- my new 390
- FE knowledge tour!
- doing some porting work
- Flairside and/or a Styleside with FE
- stock valve sizes
- Cam question
- Setting it up for Towing
- Building a 390
- Oil light on @ idle . . . Sign of the end?
- aftermarket pulleys
- Coolant Leak
- piece of tin under the intake manifold
- stroke test
- Edelbrock intake and carb on a 360
- 390 build help
- Cam specs
- Handling 3" Exhaust *Conclusion*
- Smoke rings
- Motor Mounts
- which re-manufactured 390?
- is it a 360 or a 390?
- Best 428?
- 1976 F250 390 Engine Timing
- CMF of Stock 66 352
- I took the 511 project to the scale...
- Electric fan woes.
- Good 4.25" crank
- transmission kickdown
- how much horse power does a 390 have?
- True or False (Oil related)
