In 1979 could you get a 351W in an F-250? I've been on the 351M/400 forum and it sounds to me like you couldn't. Also what is the easiest way to tell a 351W from a 351M?
I recently bought motor mounts for my 351w that I put IN a 79 4x4 chassis that CAME with a 351m. When they went to look up mounts they showed it as also being avalable with a 302, which is the same mount as a 351w. I have a 79 light truck shop manual though, and it does not show a 302 as being available. The guy at the parts store said it WAS in Mexico. Go figure ??
If you look at the engine, the first clue will be to look at the way the Radiator hooks up. In the 302/351w series engines, the Radiator hose will attack to the Intake manifold and disperse to the engine that way, If it is a cleaveland style motor(351c, 351m/400) The raditator hose will go directly to the block. This is the surest way to tell. Also, if the valve covers are stock, like said before, the cleaveland engines have 8 bolts while the windsor style has 6. The valve covers for the Cleavelands are also a bit taller for the valve clearence. I hope this helps.
The Winsor block has a removable timing chain housing behind the water pump. On the 351C/351M/400 block the timing chain housing is cast as part of the block.
The 351M is a 400 block with different crank and pistons.
