Valve cover gaskets
Old Apr 17, 2002 | 07:41 AM
scratcherky's Avatar
scratcherky
Valve cover gaskets
I have a 5.0L EFI and in process of replacing the valve cover gaskets.
I would like some opinions on what kind of gasket material is best cork or rubber? Also, the best gasket sealer, if any, would be best to use?
Thanks in advance for any info.
Don
Old Apr 17, 2002 | 10:08 AM
swirk's Avatar
swirk
Valve cover gaskets
Silicone is best. I have a silicone oil pan gasket and it is reusable and does not require adhesive or RTV. Guarenteed not to leak. My gasket is made by Felpro. I also have one on my wife's automatic tranny. I am sure that they make valve cover gaskets out of the same stuff.
Old Apr 17, 2002 | 11:27 AM
HotWhlz85's Avatar
HotWhlz85
Valve cover gaskets
This'll probably start a feud but there are two lines of thinking as far as gasket sealers go. One says any variant of RTV/silicone sealer. The other says none (my personal belief). When I replace valve cover gaskets and the like I use the yellow weatherstripping adhesive (also called elephant snot) but it's only to keep the gasket in place while putting the covers on. It has no sealing properties of it's own. The problem with a silicon sealant is that it COULD allow a gasket to move when pressure is applied to it.
I agree with swirk.........get Felpro gaskets.
Just my $.02.
Ron
Old Apr 17, 2002 | 01:43 PM
slikness's Avatar
slikness
Valve cover gaskets
I have the cast aluminum covers and I have had problems getting them to seal. I used cork, ruber with a metal crush plate, thicker cork, and finally, my mechanic bought some metal/rubber gaskets from Ford that work great!!!
Old Apr 18, 2002 | 12:03 PM
scratcherky
Valve cover gaskets
HEY fellows- thanks for the inputs. I got some the silicone gaskets and they look great even if their price is higher. Just did not want to do the job twice.
Thanks again
Don:-)
Old Apr 18, 2002 | 12:25 PM
airharley's Avatar
airharley
Valve cover gaskets
Hey Hotwhlz why not use Hi-Tack to keep the gaskets in place? Cost much less and it comes in brush (elephant snot) or spray on applications. Just a thought. Plus it's not so toxic to your health.
Old Apr 18, 2002 | 01:38 PM
HotWhlz85's Avatar
HotWhlz85
Valve cover gaskets
It's one of those "that's what I learned to use and have always done it that way" things. You know, being on auto-pilot when you do certain things although there may be a better way.
Old Apr 19, 2002 | 02:42 PM
airharley's Avatar
airharley
Valve cover gaskets
kegger66
22
Jun 30, 2016 11:16 PM
mike L
13
Oct 25, 2015 01:32 AM
jdwitte
1983 - 2012 Ranger & B-Series
Aug 16, 2004 08:30 PM
76 F150 Ranger XLT
May 18, 2004 07:20 PM
nmarlowe
Feb 11, 2004 03:10 PM
