timing chain ?
Old Jun 10, 2002 | 03:01 PM
scott9320's Avatar
scott9320
timing chain ?
o.k. I know ford retarted the timing in the early 70's. I have a 74 block i'm getting ready to rebuild. my question is can you buy a timing set for a 69 and do away with the retarted timing problem.
Old Jun 10, 2002 | 05:32 PM
BlueOvalRage's Avatar
BlueOvalRage
timing chain ?
Well, sure! Several aftermarket vendors make double roller sets with an oversize index pin hole and these cute little offset cams to change the cam retard/advance. Check around a Summit or P.A.W. catalog. If you go this route, I would get a degree wheel and degree it in when you install. Probably not wise to blindly guess which cam to use, as there are some variances in manufacturing tolerances.
Old Jun 10, 2002 | 05:35 PM
BlueOvalRage
timing chain ?
Reread your post and realized that I missed the point of your question. I doubt it. I think (may be wrong) that the replacement sets are all retarded to eliminate a part number. Have your local parts counter guy look up a '74 and a '69 to find out for sure. Otherwise, see above.
Old Jun 10, 2002 | 11:31 PM
TorqueKing's Avatar
TorqueKing
timing chain ?
Dynagear makes 2 different kinds of Ford replacement sets, one has the factory retard, the other is strait up, and both are priced the same, but check the catalogue, and make sure the saleman gets you the one that is stait up.
Cadet Second Lieutenant John F. Daly III
South Carolina Corps of Cadets, The Citadel
The TorqueKing
Old Jun 11, 2002 | 05:08 PM
BlueOvalRage
timing chain ?
Eli1644
Feb 21, 2015 11:57 AM
chevy305dbt
2004 - 2008 F150
May 19, 2013 12:18 PM
RJR99SS
28
Sep 30, 2007 05:34 PM
earlybroncoboy
Jun 5, 2007 07:46 AM
robertbourque
Mar 22, 2007 10:06 PM
