351c
Old Nov 15, 2002 | 10:15 AM
Ravin's Avatar
Ravin
351c
Hey i am rebuilding a 351c (or so i hope it is). Could some one tell me what and when it came out of. The Block numbers are D9AE-6015-ED-24.
I would like a fairly souped up engine. My other question is, what kind of heads should i look for? I have a budget of about $2500 for the complete rebuild. I want to keep the compression fairly low, in a month or two i am going to set a 641 weiand on it, and don't want to be running race fuel.
Old Nov 15, 2002 | 01:58 PM
Quantrex's Avatar
Quantrex
351c
I might be mistaken but if the block numbers are D9AE, it's not a 351C you are working with. The D9 portion of the code indicates a date of 1979; 351C's were phased out in the early '70s and were never installed from the factory in trucks (except for the Ranchero).
Old Nov 15, 2002 | 02:13 PM
Franklin2's Avatar
Franklin2
351c
[updated:LAST EDITED ON 15-Nov-02 AT 03:14 PM (EST)]Go up and look in the 351c/351m/400 forum. You will find alot of info on how to tell what you have, and what to do with it when you find out.
Old Nov 15, 2002 | 03:43 PM
lghtningstruk's Avatar
lghtningstruk
351c
Where does the thermostat housing bolt on??
Does it bolt to the intake manifold or does it bolt to the engine block. 351 Windsors have a "wet" intake manifold (coolant runs thru the intake). The 351C, 351M and the 400 have a "dry" intake.
I agree with the previous poster that is not a 351C due to the 79 model year. If it is a dry intake - it is a 351M or 400.
Old Nov 15, 2002 | 09:06 PM
Rcmgiasson's Avatar
Rcmgiasson
351c
Old Mar 29, 2005 | 07:39 PM
mustang81351w's Avatar
mustang81351w
i have a motor with the exact numbers. what i have is a 79 351w 2-bbl that came from a ford car, it is for sure not a 351c motor
lunchbox5424
Oct 26, 2024 10:47 AM
Joshrabbitt14
May 7, 2012 09:28 PM
banky
Jun 13, 2006 08:15 AM
NoAZ'68
Jan 2, 2005 09:48 AM
rexx
13
Dec 12, 2002 04:17 PM
