Thermostat temp?
Old Jun 26, 2006 | 07:51 AM
cujo8's Avatar
cujo8
Thermostat temp?
I just rebuilt my 77 302 and I changed to E7TE heads, RV cam, dual plane aluminum intake, and 4bbl 600cfm vac. secondaries Holley carb. I have both a 180F and 193F thermostat and I was wondering which was the best one to use for my application. The 180F thermostat is what came on the original carburated 77 302, but not sure if the changes I made require a higher temp thermostat. Thanks.
Jim
Old Jun 26, 2006 | 08:05 AM
63ranchwagon's Avatar
63ranchwagon
did you do any machine work, like cylinder boring? if not i would go ith the stock t-tat. give it a test trial, if it overheats or gets too hot go to a cooler t-stat. if it dosent heat up enough go with a hotter one.
Old Jun 26, 2006 | 08:57 AM
Kemicalburns's Avatar
Kemicalburns
run the 180, if it was efi i would say run the 195.
Old Jun 26, 2006 | 08:27 PM
cujo8's Avatar
cujo8
FYI The cylinders were bored out 0.030"
Old Jun 26, 2006 | 09:11 PM
scottie2hottie's Avatar
scottie2hottie
if its like any holley carb i driven its probably cold natured- go with a 193 unless it gives you problems
Old Jun 27, 2006 | 06:51 AM
cujo8's Avatar
cujo8
Well I got one vote for the 180, one for the 193, and one neutral. Need a tie breaker vote:-)
Jim
Old Jun 27, 2006 | 08:26 AM
TigerDan's Avatar
TigerDan
I'm with Kemical...go with the 180º since it's carbed. You don't need the higher combustion temps that EFI requires.
Old Jun 27, 2006 | 05:21 PM
cujo8's Avatar
cujo8
Well the 180F thermostat wins! Thanks.
Jim
