Valve stem clearance
Old Jul 1, 2006 | 04:27 PM
adunham's Avatar
adunham
I need the valve stem to rocker clearance for a 1971 302 (from a torino). The rockers are non adjustable.
thanks,
-aaron
Old Jul 2, 2006 | 12:12 PM
TigerDan's Avatar
TigerDan
There isn't any. You have hydraulic lifters which require no adjustment other than to preload the lifters on assembly. With non-adjustable rockers (yours are what's known as Positive-stop) the rocker arm nut is tightened down all the way to the shoulder on the stud and lifter preload is set by setting the valve stem height during the machining process, as in when doing a valve job.
About the only way to adjust them is by changing to a longer or shorter pushrod, which really shouldn't be neccessary.
Old Jul 5, 2006 | 08:27 PM
adunham's Avatar
adunham
That actually answers my question. My rockers (when there is no load on them from the springs) are pretty easy to turn side to side. I wasn't sure if there should be a gap there or not.
Brigart
Jan 8, 2010 07:55 AM
fordy29264
16
Sep 20, 2004 02:36 PM
fordy29264
Sep 14, 2004 12:00 AM
CANYON
Apr 28, 2004 01:02 AM
rainbowATF
Apr 18, 2004 05:45 PM
