Camshaft Options (Speed Density)
Old Nov 4, 2007 | 10:34 PM
bedmondo's Avatar
bedmondo
Hey all,
I have an 86 f-150 with the 302 EFI.
I'm looking to get a cam, specifically trying to decide between 2 cams.
The comp cams 31-255-5 or the crane 444232
I know the comp cams has slightly higher lift then the crane, and the crane has slightly more duration on the exhaust side.
My question is, for the people who have used either of these cams, what are your experiences? Which cam will produce more lowend torque v.s. an overall broad powerband?
Also, did you see any change in gas mileage? (positive or negative)
And will either of these cams change the sound of the exhaust?
Thanks!
Old Nov 5, 2007 | 04:22 AM
s1120's Avatar
s1120
No experance with the cams, but do know the heads/pistons are a little diferent on the 86 motor. Might want to check piston to valve clearance on them.
As for sound? Any cam that is SD frendly will realy not sound much diferent. Its the "lope" that makes the comp go screwy
Old Nov 5, 2007 | 08:20 AM
Conanski's Avatar
Conanski
Both will be a significant upgrade over the stock cam, more power everywhere. The sound of the motor will change, but not drastically, maybe a bit louder depending upon the exhaust system. A motor that produces more power can get better milage, but often the driver can't resist using the extra HP around town so milage may suffer. My experience is city milage goes down and hwy milage goes up.
Valve clearance is not a problem with E6TE heads on truck motors.. if that is what this vehicle has. The exception was the mustang HO motor from '86 that had flattop pistons, truck motors will have dished pistons so there is more clearance. Even then I do not believe there are clearance issues for either motor with short duration cams under 0.500" lift.
Old Nov 5, 2007 | 04:07 PM
blue beast's Avatar
blue beast
Why not go with roller rockers with 1.7:1 for added lift it is the same as adding a cam!!
Plus the added benefit of the roller for less wear and friction which frees up more ponies. It will take a lot less time and will give you a good HP boost for about $170.00.
Old Nov 5, 2007 | 04:14 PM
bedmondo's Avatar
bedmondo
well time isn't really an issue for me, i will do it as a learning project over christmas break. plus, i know atleast the crane cam+lifter kit is about $170 as well. the cam would produce a much larger improvement then changing the lifters, wouldn't it?
Old Nov 5, 2007 | 06:24 PM
Conanski's Avatar
Conanski
Originally Posted by bedmondo
the cam would produce a much larger improvement then changing the rockers, wouldn't it?
Oh yeah.. will it ever. The stock cam in that motor has 0.378" and 0.390" total lift. 1.72 rockers only brings that up to 0.398" and 0.414" lift. The motor will make more power with any lift increase up to 0.500" lift, so don't be shy.
Old Nov 5, 2007 | 07:19 PM
bedmondo's Avatar
bedmondo
does anybody know if the comp cams comes with lifters? if not, that would push the total cost way up...unless I can use the stock lifters? (50k miles) I believe the comp cams is a little better then the crane correct? (more lift)
conanski, I know you have the crane 444232, what are your opinions on it v. the comp cams in my little 302?
Old Nov 5, 2007 | 07:43 PM
Brawny's Avatar
Brawny
I don't believe the Comp cam is available with lifters as a kit. At least not thru Summit or Jegs. I just bought the Crane for the same reason. Plus I have had great experiences in the past with Crane (not to say I have had any bad ones with Comp).
The lift is a touch higher on the Comp cam but in comparison to the stocker I think its not enough to worry about. I won't have my engine back together for another 2 weeks so I have no actual opinion on it until then.
Old Nov 6, 2007 | 03:35 AM
KDPate's Avatar
KDPate
Heres another option that is less expensive : the replacement cam for a 351W.....http://www.northernautoparts.com/Pro...tModelId=11115
Doesn't have as much lift as the COMP or Crane, but is half the cost. Plus that extra money can go to new lifters (mandatory on a hydraulic flat tappet cam) and a new roller timing chain...
Old Nov 6, 2007 | 08:00 AM
Conanski's Avatar
Conanski
Originally Posted by KDPate
Heres another option that is less expensive : the replacement cam for a 351W.....http://www.northernautoparts.com/ProductModelDetail.cfm?ProductModelId=11115
I can't recommend that cam for 2 reasons, the duration is way too long for a 302 truck motor, and the plug firing order won't match the 302 injector firing order(even though it's batch fire it will cause idle issues). Actually that's a strike against the 444232 as well in this case....
Old Nov 6, 2007 | 10:37 AM
bedmondo's Avatar
bedmondo
i thought that people ran the 351 cams with no problem...just have to switch the plug wires to match the 351 order don't you?
Old Nov 6, 2007 | 10:50 AM
Conanski's Avatar
Conanski
Yes, the motor will run just by switching the plug wires.. but some people have reported some rough idle issues with this swap, other didn't notice. You can choose to wait and see if you have a problem, and then fix it by rewiring the injectors, or avoid the potential problem and get a cam that matches the native firing order.
Old Nov 6, 2007 | 06:23 PM
bedmondo's Avatar
bedmondo
well, i was thinking of doing a mass-air swap at the same time, because it would make everything cheaper/more efficient in the long run. do you think there would be a better cam for me to choose if i went with mass-air instead? Then i could successfully run the 351 cam with no compatibility issues with the mass-air system.
Old Nov 8, 2007 | 02:07 AM
KDPate's Avatar
KDPate
We'll find out this winter when it goes in. I don't think there will be an idle issue with it (might be minimal at worst) but I do agree with your point on the duration. It might be too long for a 302 but that remains to be seen.
'89F2urd
Oct 26, 2011 06:13 PM
Jsbiohazard
15
Mar 13, 2006 01:33 PM
pbear6969
Jan 9, 2006 07:34 AM
1976 drag
27
Aug 27, 2004 10:56 PM
freejay
15
Aug 29, 2003 09:57 PM
