White Smoke - Unconventional Setup Help
Old Aug 18, 2008 | 03:00 PM
53OlderThanMe's Avatar
53OlderThanMe
I have a 71 302 stock internals. I have swapped the intake manifold, carbs and valve covers as shown with a 2x2 adapter. Engine fires right up and idles fine. After a few minutes white smoke comes from the valve covers if I pull the breather it will flow direct from the breather hole, if not it looks like the valve covers themselves are smoking. Pretty sure I have a venting problem as I don't have a radiator hooked up. Any ideas on best way to vent this setup? Thanks
Old Aug 18, 2008 | 03:19 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Hoping you have a PCV in the other valve cover.
Old Aug 18, 2008 | 03:25 PM
53OlderThanMe
No, original 2BBL setup had ECG plate under carb. Original valve covers had breather going to ECG and Air cleaner.
Old Aug 18, 2008 | 06:20 PM
marks69's Avatar
marks69
i wouldn't be running it to long with no coolant. when i got pulled over last time by the ministry i was almost fined for not having a working pcv valve on the truck. their book said our trucks had one back then.
Old Aug 18, 2008 | 08:57 PM
Blurry94's Avatar
Blurry94
The closed breathers have a metal flap inside them. You may need to push it open a little further. Is there a breather on the other side?
Old Aug 18, 2008 | 09:26 PM
53OlderThanMe
Yes breathers on both sides, I agree they don't seem to be breathing too well. The breathers have (2) half dime size holes on either side of the metal strip that crosses the bottom to lock it onto the valve cover. These holes open up into a foam filter element. Maybe I'll try some different breathers before I go the PVC route.
Old Aug 21, 2008 | 11:10 AM
LOUS F100's Avatar
LOUS F100
I would go with a pvc system and not the open breathers. A closed breather on 1 valve cover with a hose the the air cleaner, and a pcv valve on theother valve cover going to the base of the carb.
Old Aug 21, 2008 | 03:28 PM
Blurry94's Avatar
Blurry94
I would think that those two breathers would be enough to vent the pressure. Nothing wrong with running a PCV system if you have the means. Otherwise, open element breathers work fine. I've been running them for several years without any problems.
Old Aug 21, 2008 | 06:24 PM
Holmesuser01's Avatar
Holmesuser01
I remember back around 1960, my dad had a '60 Ford Falcon with a 6 cylinder. It had a breather like yours, but it also had a large pipe that went from the back of the valve cover down the side of the engine, and had a snout that opened into the air stream under the car.
I think that was the way most cars vented the crankcase back then.
You need to just install a PCV valve. I think they make an adaptor to fit in one of the holes you have in your cover. The vacuum will pull air thru your current oil filler breather, thru the block, and then burn the fumes in the engine.
danzigs
Dec 22, 2010 04:05 AM
naystcb
Jan 31, 2010 09:21 PM
harrytoes
Jun 3, 2007 09:10 AM
racsan
Sep 4, 2006 09:15 PM
mikeeep
Jan 17, 2003 11:32 AM
