which cam
</td> <td width="150"> CCA-35-255-5
</td> <td width="150"> CCA-31-255-5
</td> </tr> <tr class="price"> <td class="dimensions" width="150">
</td></tr></tbody></table><table style="width: 353px; height: 1194px;" id="compare" border="0" cellpadding="0" cellspacing="0"><tbody><tr style="background-color: rgb(239, 239, 239);" class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "><td class="dimensions" width="150">Description
</td> <td width="150"> Camshaft, Hydraulic Flat Tappet, Advertised Duration 254/ 258, Lift .478/ .485, Ford, Small Block, Each
</td><td width="150"> Camshaft, Hydraulic Flat Tappet, Advertised Duration 250/ 260, Lift .462/ .474, Ford, Small Block, Each
</td></tr> <tr style="background-color: rgb(239, 239, 239);" class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150">
</td></tr> <tr style="background-color: rgb(239, 239, 239);" class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150"> Advertised Duration
</td> <td width="150"> 254 int./258 exh.
</td> <td width="150"> 250 int./260 exh.
</td> </tr> <tr style="background-color: rgb(239, 239, 239);" class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150"> Advertised Exhaust Duration
</td> <td width="150"> 258
</td> <td width="150"> 260
</td> </tr> <tr style="background-color: rgb(239, 239, 239);" class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150"> Advertised Intake Duration
</td> </tr> <tr style="background-color: rgb(239, 239, 239);" class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150"> Basic Operating RPM Range
</td> <td width="150"> 1,000-5,200
</td> </tr> <tr class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150"> CARB EO Number
</td> <td width="150"> -
</td> </tr> <tr class="space-line"> <td class="dimensions" width="150">
</td> <td>
</td> <td>
</td> </tr> <tr class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150"> Cam Style</td> <td width="150"> Hydraulic flat tappet
</td> </tr> <tr style="background-color: rgb(239, 239, 239);" class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150"> Camshaft Gear Attachment
</td> </tr> <tr class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150"> Computer Controlled Compatible
</td> <td width="150"> Yes
</td> <td width="150"> No
</td> </tr> <tr class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150"> Duration at 050 inch Lift
</td> <td width="150"> 210 int./214 exh.
</td> <td width="150"> 206 int./212 exh.
</td> </tr> <tr class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150"> Exhaust Duration at 050 inch Lift
</td> <td width="150"> 214
</td> <td width="150"> 212
</td> <td>
</td> <td>
</td> </tr> <tr class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150"> Exhaust Valve Lash</td> <td width="150"> 0.000 in.
</td> </tr> <tr style="background-color: rgb(239, 239, 239);" class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150"> Exhaust Valve Lift with Factory Rocker Arm Ratio
</td> <td width="150"> 0.485 in.
</td> <td width="150"> 0.474 in.
</td> </tr> <tr style="background-color: rgb(239, 239, 239);" class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150"> Footnotes
</td> </tr> <tr style="background-color: rgb(239, 239, 239);" class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150"> Grind Number
</td> <td width="150"> FW XE254H-14
</td> <td width="150"> FS XE250H-14
</td> </tr> <tr style="background-color: rgb(239, 239, 239);" class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150"> Intake Duration at 050 inch Lift
</td> <td>
</td> <td>
</td> </tr> <tr style="background-color: rgb(239, 239, 239);" class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150"> Intake Valve Lash</td> <td width="150"> 0.000 in.
</td> </tr> <tr style="background-color: rgb(239, 239, 239);" class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150"> Intake Valve Lift with Factory Rocker Arm Ratio
</td> <td width="150"> 0.478 in.
</td> <td width="150"> 0.462 in.
</td> </tr> <tr style="background-color: rgb(239, 239, 239);" class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150"> Lobe Separation (degrees)
</td> <td width="150"> 114
</td> </tr> <tr style="background-color: rgb(239, 239, 239);" class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150"> Notes
</td> </tr> <tr style="background-color: rgb(239, 239, 239);" class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150"> Quantity
</td> <td width="150"> Sold individually.
</td> <td>
</td> <td>
</td> </tr> <tr style="background-color: rgb(239, 239, 239);" class="value" onmouseover="this.className='';this.style.backgrou ndColor='#efefef';" onmouseout="this.className='value'; "> <td class="dimensions" width="150"> Valve Lift with Factory Rocker Arm Ratio</td> <td width="150"> 0.478 int./0.485 exh. lift
</td> <td width="150"> 0.462 int./0.474 exh. lift
I have the gt40 explorer intake, not on truck yet. and i'm gonna port the ex side of my e7's. Out of these similar cams which is gonna give me the best torque in the lowest rpm range.
btw, i'm USAF stationed in ga, but i'm from mid eastern oregon. hows the weather and fires seasons been doing back at home
