so ive been pondering about this for a good while... lets say a 460 with 62cc heads makes an alarming compression, but a 302 with 62cc heads yeilds a faily low compression. If the 302/351W heads were symmetrical from 87+ did the 351 have a slightly higher compression? or did ford realize this and put a mild dish on the 351 to lower the said compression?
Piston Compression height is measured from the pin center line to the flat portion of the piston. If it's not the same for both pistons there will be trouble during assembly.
its only a question man... chill out, im not about to tear apart any engines... yet.
im jus saying, since the 351 pistons are dished, then add flat-top/flycut pistons (302) you would increase compresion ratio slightly... thats all, and thank you guys for answering my question
Compression heights vary, but the most basic list seems to indicate a significant difference between the two. In addition, they list the pistons specifically for 302 or 351, not both as far as I can see.
So yes, flat tops will bump up the CR, but there is a flat top specifically for whatever iron you're running.
Compression height is what makes a 302 piston a 302 piston and a 351w piston a 351W piston. Compression ratio is determined by head volume, cylinder volume and piston dome /dish cc. Boring a 4" hole oversize will raise the compression slightly. The difference in CH between the 302 is great enough that a piston swap would drive the piston into the head with a stock rod. When the stroke of the crank is increased to 3.85, a 302 piston will then fit with a higher CR. A 302 piston could theoretically be used in a 351w with the stock 3.50 stroke, but the rod length would then have to be shortened by the difference in CH between the 302 and the 351W pistons, but then most likely the pistons would hit the counterweights. Nice try, but there really isn't any parts swaps that work out like that. Bottom line- a 351W with stock stroke needs 351W pistons. A swap to 351W flat top pistons would give an appreciable boost in CR.
