Header installation
Old Feb 22, 2001 | 01:00 AM
bigsix's Avatar
bigsix
Header installation
Old Feb 23, 2001 | 06:33 AM
77f100's Avatar
77f100
Header installation
Well I've just installed a set of Dynomax dual headers on my 77 F100, 300I. The problem is the rear header is lining up with the crossmember. I either need a different crossmember that has a droop built in (so the exhaust goes over it). Or I need to modify the existing crossmember by maybe lowering it, bolting it below the frame rails with spacers.
Any takers?
Old Feb 23, 2001 | 10:20 AM
steakman_usaf's Avatar
steakman_usaf
Header installation
Do you think that if you took your header to an exhaust shop, they could properly heat and bend the header a few degrees? I know a shop in town that'll make you custom headers and will modify existing ones.
Maybe something to try...
Chris
1982 F100 Flareside
300 I-6 SROD 4speed
MSD6AL, 8.5mm S/C Wires
Blaster 2F Coil
Blue & Silver
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
