Engine Miss, Skip, Stumble
Old Feb 24, 2001 | 08:43 PM
Trail_Rider's Avatar
Trail_Rider
Old Feb 25, 2001 | 03:35 PM
beefie13's Avatar
beefie13
Have a 93 F150 2WD w/ 106K miles & no prior engine problems.
Engine skips, misses at steady speeds or slight accel. Problem is intermittent and is worst at 30-50 mph when truck shudders.
Dealer mechanic says plugs, wires, ignition, IAC & air sys, filters are all OK & no codes are in computer and that I may have to just live with it! I have run 3 tanks new gas w/ injector cleaner thru w/ no change.
Any ideas or solutions out there.
I'd appreciate any input. Thanks.
Old Feb 26, 2001 | 03:01 AM
hotrodford_88's Avatar
hotrodford_88
Have an injector service done on the injectors. The add in tank stuff usually won't do it. If yuo can find a nearby shop that has a Motor Vac. It will clean all of the carbon out of your engine, I had this done when my truck had the 6 in it, and it did run better. Also, the bucking could be caused by a plugged catalytic convertor, if everything else checks out ok. Have the convertors checked by a muffler shop for backpressure, if there is too much backpressure, then it will build up and caus the bucking feeling you are getting.
My own truck did this, I spent over $1,000 trying to figure out what was wrong. Replaced all sensors, distributor, numerous set of plugs, plug wires, and finally ended up being the catalytic convertor. Talk about aggravated, after over $1,000 and I still didn't get any better mileage out of it, I swapped the engine out.
1988 F-150, SWB, 5.0 EFI (formerly 4.9 EFI), M5OD 5 speed, 3.08 gears, Summit shorty truck headers, Custom built Flowmaster exhaust system. Force 4 LP6000 lightbar, Federal signal PA-300 100 watt siren, Icom IC-V100 50 watt mobile radio.
1965 F-100 (just purchased 1/18/01), SWB, 390, C-6 auto. Dual exhaust, Not much else to do to it.
Can see both below.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
